| r5 alpine turbo or maxi forever fan - r21t custom injection | |
+30Joel PEPE mig33 yanpol GTZS willyam ESBC sylvain2206 a5coupe jeremy76 tour de corse labossemo captainkuru mr5q cléon51300 turbaux1 nico camboui76 capitainecaverne maxime73 Vyterra fab.17 fab421 jérémy nico8221 steve fred02 le quinquin63 jp.isurf tao13 34 participants |
| Sujet: Re: r5 alpine turbo or maxi forever fan - r21t custom injection Jeu 22 Jan - 10:25 | |
tao13 Apprenti Turbistes
| Sujet: Re: r5 alpine turbo or maxi forever fan - r21t custom injection Jeu 22 Jan - 14:28 | |
| sorry but i don't understand this proposition in francaise if you can translate in english please thanks a lot have a nice day | |
jeremy76 Adhérent du
| Sujet: salut Jeu 22 Jan - 18:15 | |
a5coupe Habitué Turbistes
| Sujet: Re: r5 alpine turbo or maxi forever fan - r21t custom injection Ven 23 Jan - 12:20 | |
| hello, what a project.. can you tell me what kind of wheels there are available for the dacia with the 3 holes wheel? I think there are some after market wheels for sale in Romania? I might need some for my 5 alpine coupe.. thanks in advance Marcel | |
| Sujet: Re: r5 alpine turbo or maxi forever fan - r21t custom injection Ven 23 Jan - 12:57 | |
| Sujet: Re: r5 alpine turbo or maxi forever fan - r21t custom injection Dim 8 Mar - 20:55 | |
| finaly i "paint" it https://servimg.com/view/12638042/68 https://servimg.com/view/12638042/69 https://servimg.com/view/12638042/70 https://servimg.com/view/12638042/71 https://servimg.com/view/12638042/72 | |
ESBC Membre de Bronze
| Sujet: Re: r5 alpine turbo or maxi forever fan - r21t custom injection Lun 9 Mar - 1:42 | |
| Hello Good welcome | |
| Sujet: r5 alpine or alpine turbo or turbo 2 or maxi forever fun Lun 9 Mar - 9:10 | |
GTZS Pro pilotes Turbistes
| Sujet: Re: r5 alpine turbo or maxi forever fan - r21t custom injection Lun 9 Mar - 19:50 | |
| Sujet: Re: r5 alpine turbo or maxi forever fan - r21t custom injection Ven 1 Mai - 18:27 | |
| for new "papillon d'admission" (excuse my francaise) https://servimg.com/view/12638042/73 https://servimg.com/view/12638042/74 https://servimg.com/view/12638042/75 a new positions https://servimg.com/view/12638042/76 https://servimg.com/view/12638042/77 | |
mig33 Membre d'Argent
| Sujet: Re: r5 alpine turbo or maxi forever fan - r21t custom injection Ven 1 Mai - 22:49 | |
| C est pas un peu petit le diametre des tubulures | |
| Sujet: Re: r5 alpine turbo or maxi forever fan - r21t custom injection Sam 2 Mai - 21:02 | |
| diamètre de la tubulature est le même com l'entrée dans la cullasse moins de 2 mm de diamètre .......... il devrait y avoir aucun problème de toute façon je vais maintenant avec à une galerie de montagne avec une entrée inspiré Solex 32 DIS de 27mm et la nouvelle galerie a un diammete de 30mm sur chaque piston ........ I say it's OK s'il vous plaît me dire si toute erreur de conception de toute façon vous essayez de ce projet
excuse my francaise | |
PEPE Habitué Turbistes
| Sujet: Re: r5 alpine turbo or maxi forever fan - r21t custom injection Lun 4 Mai - 0:37 | |
| Sujet: Re: r5 alpine turbo or maxi forever fan - r21t custom injection Ven 29 Mai - 8:54 | |
| another photo https://servimg.com/view/12638042/79 https://servimg.com/view/12638042/80 https://servimg.com/view/12638042/81 https://servimg.com/view/12638042/82 | |
| Sujet: Re: r5 alpine turbo or maxi forever fan - r21t custom injection Ven 26 Juin - 14:41 | |
| in english:I tried to do a test. I said I have a clunch 180mm, which is not going well either 0.6 bar. I increased the pressure to 0.9 bar. see what happens in the movie. https://www.youtube.com/watch?v=1DpOowTKC8M however little run gas pedal at any stage, from 3000 rpm when the turbine starts, clutch stop you at all, dont' work,spins in the empty. movie is in step-5.
in francaise:J'ai essayé de faire un test. J'ai dit que je suis comme une conduite de pression et de 180 mm, ce qui ne va pas bien, soit 0,6 bar. J'ai augmenté la pression à 0,9 bar. voir ce qui se passe dans le film. https://www.youtube.com/watch?v=1DpOowTKC8M Mais peu de la pédale de gaz à exécuter à tout moment, à partir de 3000 tours lorsque l'éolienne démarre, l'embrayage vous arrêter à tous,tourne dans le vide. film est à l'vittesse-5. | |
| Sujet: Re: r5 alpine turbo or maxi forever fan - r21t custom injection Sam 27 Juin - 19:40 | |
| Sujet: Re: r5 alpine turbo or maxi forever fan - r21t custom injection Lun 29 Juin - 8:54 | |
| l'embrayage est neuf, est un Sachs, mais il est 180 mm sur un volant de l'Alpine turbo 115ch. J'ai essayé il ya 2 ans avec un volant d'inertie de r5gtt de 200mm mais modifcata beaucoup de peine et je electromoteur, d-que je suis retourné à l'alpine turbo stabndard 180. | |
| Sujet: Re: r5 alpine turbo or maxi forever fan - r21t custom injection Mar 30 Juin - 1:28 | |
| Peut-être que ton volant moteur ou le disque d'embrayage est gras (huile). Peut-être aussi ton mécanisme est-il mort . Tu l'avais changé ? | |
| Sujet: Re: r5 alpine turbo or maxi forever fan - r21t custom injection Mar 30 Juin - 15:31 | |
| est nouveau. est modifié. il y avait l'huile sur l'embrayage. J'ai augmenté la pression turbo d'embrayage et de ne pas vous. sont très bien le couple de la voiture .... c'est l'explication. Je suis un banc d'essai | |
| Sujet: Re: r5 alpine turbo or maxi forever fan - r21t custom injection Mar 30 Juin - 23:43 | |
| Sujet: Re: r5 alpine turbo or maxi forever fan - r21t custom injection Mer 1 Juil - 22:14 | |
| Excuses moi, mais je n'ai rien compris à ton explication. | |
| Sujet: Re: r5 alpine turbo or maxi forever fan - r21t custom injection Mer 1 Juil - 22:26 | |
| :bienvv: Pas mieux, pour moi, tu as de l'huile au niveau embrayage/volant moteur............en tous cas, c'est se que je pense | |
| Sujet: Re: r5 alpine turbo or maxi forever fan - r21t custom injection Jeu 2 Juil - 21:28 | |
| la problème c'est l'embrayage qui ne plus faire face, car trop de couple développé par le 1,2 bar, est un embrayage de 180 mm standard alpine atmospherique par 90ch.
demain je vais filmer, à une pression plus bas, quelque part dans le 0.8 et peutetre je vais aller a un stand de probe | |
| Sujet: Re: r5 alpine turbo or maxi forever fan - r21t custom injection Ven 3 Juil - 12:04 | |
| excuse le tournage, mais une poignée de conduire et un a été abattu, n'est pas facile. premier film est en ville, avec une pression de 0,7 bar, il ya place pour des tests. Le deuxième film est sur une route à l'extérieur de la ville, avec une pression de 0,7, à un moment de briser un tuyau de pression et la voiture n'est plus supérieure à 0,4 bar. la troisième est avec un tuyau cassé, 0.3-0.4 bar, et les freins arrière bloqué. à subir son procès, nous ne pouvions pas prendre parce que la voiture est trop bas et frappé dans le rôle. 1. https://www.youtube.com/watch?v=0zbP4cBac9k 2. https://www.youtube.com/watch?v=ZFQaYxBXa0g 3. https://www.youtube.com/watch?v=it52pMOPyQc conclusion est évidente, embrayage de ne plus faire face à la barre de 0,8. excuse le français, mais la traduction est faite en google | |
| Sujet: Re: r5 alpine turbo or maxi forever fan - r21t custom injection | |
